Ir para o conteúdo principal
Samsung Gravity SGH-T669 Front Glass Assembly Replacement
O que você precisa
  1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: passo 1, imagem 1 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: passo 1, imagem 2 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: passo 1, imagem 3 %32
    • Make sure your phone is powered off.
    • Use a plastic opening tool to remove the rear battery cover.
  2. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 2, imagem 1 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 2, imagem 2 %32
    • Remove the battery by pulling up from the bottom right corner.
    • Remove the SIM card and the Micro SD card.
    • SIM card
    • Micro SD card
  3. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Casing: passo 3, imagem 1 %32
    • Remove the six 2.8 mm Phillips screws.
  4. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 4, imagem 1 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 4, imagem 2 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to pry off the casing.
    • The volume button, camera button, and lock button may fall out as you remove the casing. If they are still on the phone, remove them.
    • Lock button
    • Camera button
    • Volume button
  5. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Motherboard: passo 5, imagem 1 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Motherboard: passo 5, imagem 2 %32
    • Disconnect the LCD cable with a plastic opening tool.
    • Remove the two 2.8 mm Phillips screws that hold the motherboard in place.
  6. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 6, imagem 1 %32
    • Remove motherboard.
  7. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Separating the halves: passo 7, imagem 1 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Separating the halves: passo 7, imagem 2 %32
    • Remove the six 1.5 mm Phillips screws.
    • Very gently peel the LCD cord off the slider assembly.
  8. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 8, imagem 1 %32
    • Remove the keyboard housing from the screen housing.
  9. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Screen casing: passo 9, imagem 1 %32
    • Remove the four 2.5 mm Phillips screws.
  10. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 10, imagem 1 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 10, imagem 2 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 10, imagem 3 %32
    • I found that my plastic opening tool wasn't strong enough (it broke) to pry open this casing.
    • I used a 1.3 mm Flathead screwdriver as an opening tool.
    • After you have gotten under the edge of the back plate, slide your tool along the length of the plate.
    • Be careful if using a screwdriver to open the casing. While there are a minimal amount of components that can be damaged, caution should be exercised. It is not recommended.
  11. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 11, imagem 1 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 11, imagem 2 %32
    • Remove the cover.
    • There are four clips on the underside of the cover, shown in the green and yellow boxes.
    • I found these clips to be the hardest to remove.
    • After removing the yellow clips, these should follow easily.
  12. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Remove the LCD: passo 12, imagem 1 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Remove the LCD: passo 12, imagem 2 %32
    • It's time to take the LCD out.
    • Begin by removing the blue piece of tape.
  13. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 13, imagem 1 %32 Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 13, imagem 2 %32
    • Disconnect the two ZIF connections using a plastic opening tool.
    • ZIF #1
    • ZIF #2
  14. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 14, imagem 1 %32
    • Use a plastic opening tool on the bottom of the LCD to pry it off.
  15. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: passo 15, imagem 1 %32
    • Remove the LCD panel.
Conclusão
Andrew Schneider
Membro desde: 05/31/14
970 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,410
