Introdução
Use this guide to replace your cracked or otherwise damaged front panel, including the front glass, digitizer, and front panel buttons.
O que você precisa
Disconnect the LCD cable with a plastic opening tool.
Remove the two 2.8 mm Phillips screws that hold the motherboard in place.
Remove the six 1.5 mm Phillips screws.
Very gently peel the LCD cord off the slider assembly.
It's time to take the LCD out.
Begin by removing the blue piece of tape.
