Ir para o conteúdo principal
Samsung Glyde Motherboard Replacement
O que você precisa
  1. Samsung Glyde Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Samsung Glyde Motherboard Replacement, Motherboard: passo 3, imagem 2 %32
    • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
  4. Samsung Glyde Motherboard Replacement: passo 4, imagem 1 %32 Samsung Glyde Motherboard Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  5. Samsung Glyde Motherboard Replacement: passo 5, imagem 1 %32 Samsung Glyde Motherboard Replacement: passo 5, imagem 2 %32
    • The green film above the camera is the camera connector to the motherboard.
    • Use a plastic opening tool to disconnect the camera connector.
  6. Samsung Glyde Motherboard Replacement: passo 6, imagem 1 %32 Samsung Glyde Motherboard Replacement: passo 6, imagem 2 %32
    • The golden film connector connects the keyboard to the motherboard.
    • Use a plastic opening tool to disconnect the keyboard connector.
  7. Samsung Glyde Motherboard Replacement: passo 7, imagem 1 %32 Samsung Glyde Motherboard Replacement: passo 7, imagem 2 %32
    • The circular connector holds the motherboard in place.
    • Using a plastic opening tool, disconnect the circular connector.
  8. Samsung Glyde Motherboard Replacement: passo 8, imagem 1 %32 Samsung Glyde Motherboard Replacement: passo 8, imagem 2 %32 Samsung Glyde Motherboard Replacement: passo 8, imagem 3 %32
    • There is a LCD connector underneath the motherboard.
    • Gently lift the far edge of the motherboard upwards toward the center of the phone.
    • Using a plastic opening tool, disconnect the LCD connector.
  9. Samsung Glyde Motherboard Replacement: passo 9, imagem 1 %32 Samsung Glyde Motherboard Replacement: passo 9, imagem 2 %32
    • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
Conclusão
Stephen
Membro desde: 10/12/11
26 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 3-12, Regan Fall 2011 Membro de Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,134
