Ir para o conteúdo principal
Samsung Gear VR with Controller Motherboard Replacement
O que você precisa
  1. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: passo 1, imagem 1 %32 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: passo 1, imagem 2 %32 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: passo 1, imagem 3 %32
    • Turn the controller upside down to access the battery compartment.
    • The battery compartment is located on the opposite side of the buttons.
    • Press on the top of the battery plate and slide down to remove the cover.
  2. Samsung Gear VR with Controller Motherboard Replacement: passo 2, imagem 1 %32 Samsung Gear VR with Controller Motherboard Replacement: passo 2, imagem 2 %32 Samsung Gear VR with Controller Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the AAA batteries using your fingers.
  3. Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: passo 3, imagem 1 %32 Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: passo 3, imagem 2 %32
    • Remove the four 5mm Phillips #000 screws.
  4. Samsung Gear VR with Controller Motherboard Replacement: passo 4, imagem 1 %32
    • Use the metal spudger to pry the back side of the controller apart from the front.
    • You will have to use the spudger in many different spots along the divide before trying to separate the pieces.
  5. Samsung Gear VR with Controller Motherboard Replacement: passo 5, imagem 1 %32 Samsung Gear VR with Controller Motherboard Replacement: passo 5, imagem 2 %32
    • Pull apart the two halves of the controller to access the motherboard.
  6. Samsung Gear VR with Controller Motherboard Replacement: passo 6, imagem 1 %32 Samsung Gear VR with Controller Motherboard Replacement: passo 6, imagem 2 %32 Samsung Gear VR with Controller Motherboard Replacement: passo 6, imagem 3 %32
    • Pry on the two pop connectors with the plastic opening tool to detach the motherboard.
    • Separate the motherboard and trackpad from the rear part of the controller.
Conclusão
Jake Criscione
Membro desde: 01/24/19
587 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S18-G3, White Winter 2019 Membro de Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 974
