Ir para o conteúdo principal
Samsung Gear VR With Controller Lens Replacement
O que você precisa
  1. Samsung Gear VR With Controller Lens Replacement, Inner Mask: passo 1, imagem 1 %32 Samsung Gear VR With Controller Lens Replacement, Inner Mask: passo 1, imagem 2 %32 Samsung Gear VR With Controller Lens Replacement, Inner Mask: passo 1, imagem 3 %32
    • Push the switch on the right-hand side of the device to separate the cover from the main body.
    • Pull the cover away from the main device.
    Pergunte ao FixBot
    Comentar
  2. Samsung Gear VR With Controller Lens Replacement: passo 2, imagem 1 %32 Samsung Gear VR With Controller Lens Replacement: passo 2, imagem 2 %32 Samsung Gear VR With Controller Lens Replacement: passo 2, imagem 3 %32
    • Remove the four corner screw covers with a metal spudger.
    • The screw covers fly off when removed, so make sure to keep track of them.
    Pergunte ao FixBot
    Comentar
  3. Samsung Gear VR With Controller Lens Replacement: passo 3, imagem 1 %32 Samsung Gear VR With Controller Lens Replacement: passo 3, imagem 2 %32 Samsung Gear VR With Controller Lens Replacement: passo 3, imagem 3 %32
    • Use a metal spudger to remove the screw cover centered at the top.
    Pergunte ao FixBot
    Comentar
  4. Samsung Gear VR With Controller Lens Replacement: passo 4, imagem 1 %32 Samsung Gear VR With Controller Lens Replacement: passo 4, imagem 2 %32 Samsung Gear VR With Controller Lens Replacement: passo 4, imagem 3 %32
    • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
    • Lift the front phone mount up and to the left.
    • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
    Pergunte ao FixBot
    Comentar
  5. Samsung Gear VR With Controller Lens Replacement: passo 5, imagem 1 %32 Samsung Gear VR With Controller Lens Replacement: passo 5, imagem 2 %32
    • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
    • Pull the plate away from the motherboard gently.
    Pergunte ao FixBot
    Comentar
  6. Samsung Gear VR With Controller Lens Replacement: passo 6, imagem 1 %32 Samsung Gear VR With Controller Lens Replacement: passo 6, imagem 2 %32
    • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
    • You can now completely remove the front phone mount from the headset.
    Pergunte ao FixBot
    Comentar
  7. Samsung Gear VR With Controller Lens Replacement: passo 7, imagem 1 %32 Samsung Gear VR With Controller Lens Replacement: passo 7, imagem 2 %32 Samsung Gear VR With Controller Lens Replacement: passo 7, imagem 3 %32
    • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
    • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
    • The largest pop connector may require more effort to remove.
    • Make sure that nothing is connected to the motherboard before you pull it out.
    Pergunte ao FixBot
    Comentar
  8. Samsung Gear VR With Controller Lens Replacement: passo 8, imagem 1 %32 Samsung Gear VR With Controller Lens Replacement: passo 8, imagem 2 %32 Samsung Gear VR With Controller Lens Replacement: passo 8, imagem 3 %32
    • Remove the eight 5mm Phillips #000 screws on the inner mask.
    • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
    Pergunte ao FixBot
    Comentar
  9. Samsung Gear VR With Controller Lens Replacement, Lens: passo 9, imagem 1 %32 Samsung Gear VR With Controller Lens Replacement, Lens: passo 9, imagem 2 %32
    • Use the metal spudger to press on the three tabs around each of the sockets.
    • Press the tabs gently to prevent damaging them.
    • Pull out the lenses with your fingers to remove them from the mask.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Jake Criscione
Membro desde: 01/24/19
587 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S18-G3, White Winter 2019 Membro de Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 34
Ao todo: 1,257
