Ir para o conteúdo principal
Samsung Gear VR With Controller Focus Wheel Replacement
O que você precisa
  1. Samsung Gear VR With Controller Focus Wheel  Replacement, Inner Mask: passo 1, imagem 1 %32 Samsung Gear VR With Controller Focus Wheel  Replacement, Inner Mask: passo 1, imagem 2 %32 Samsung Gear VR With Controller Focus Wheel  Replacement, Inner Mask: passo 1, imagem 3 %32
    • Push the switch on the right-hand side of the device to separate the cover from the main body.
    • Pull the cover away from the main device.
  2. Samsung Gear VR With Controller Focus Wheel  Replacement: passo 2, imagem 1 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 2, imagem 2 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 2, imagem 3 %32
    • Remove the four corner screw covers with a metal spudger.
    • The screw covers fly off when removed, so make sure to keep track of them.
  3. Samsung Gear VR With Controller Focus Wheel  Replacement: passo 3, imagem 1 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 3, imagem 2 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 3, imagem 3 %32
    • Use a metal spudger to remove the screw cover centered at the top.
  4. Samsung Gear VR With Controller Focus Wheel  Replacement: passo 4, imagem 1 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 4, imagem 2 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 4, imagem 3 %32
    • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
    • Lift the front phone mount up and to the left.
    • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
  5. Samsung Gear VR With Controller Focus Wheel  Replacement: passo 5, imagem 1 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 5, imagem 2 %32
    • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
    • Pull the plate away from the motherboard gently.
  6. Samsung Gear VR With Controller Focus Wheel  Replacement: passo 6, imagem 1 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 6, imagem 2 %32
    • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
    • You can now completely remove the front phone mount from the headset.
  7. Samsung Gear VR With Controller Focus Wheel  Replacement: passo 7, imagem 1 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 7, imagem 2 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 7, imagem 3 %32
    • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
    • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
    • The largest pop connector may require more effort to remove.
    • Make sure that nothing is connected to the motherboard before you pull it out.
  8. Samsung Gear VR With Controller Focus Wheel  Replacement: passo 8, imagem 1 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 8, imagem 2 %32 Samsung Gear VR With Controller Focus Wheel  Replacement: passo 8, imagem 3 %32
    • Remove the eight 5mm Phillips #000 screws on the inner mask.
    • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
  9. Samsung Gear VR With Controller Focus Wheel  Replacement, Focus Wheel: passo 9, imagem 1 %32 Samsung Gear VR With Controller Focus Wheel  Replacement, Focus Wheel: passo 9, imagem 2 %32 Samsung Gear VR With Controller Focus Wheel  Replacement, Focus Wheel: passo 9, imagem 3 %32
    • Remove the one 5mm Phillips #000 screw.
    • The screw for the focus wheel has a larger head than the rest of the screws.
    • Separate the focus wheel from the headset using your fingers.
Conclusão
Uma outra pessoa concluiu este guia.
Harumi Hokari
Membro desde: 01/24/19
243 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G3, White Winter 2019 Membro de Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 276
