Ir para o conteúdo principal
Samsung Gear VR Lens Replacement
O que você precisa
  1. Samsung Gear VR Lens Replacement, Front Phone Mount: passo 1, imagem 1 %32 Samsung Gear VR Lens Replacement, Front Phone Mount: passo 1, imagem 2 %32 Samsung Gear VR Lens Replacement, Front Phone Mount: passo 1, imagem 3 %32
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
    Pergunte ao FixBot
    Comentar
  2. Samsung Gear VR Lens Replacement: passo 2, imagem 1 %32 Samsung Gear VR Lens Replacement: passo 2, imagem 2 %32
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
    Pergunte ao FixBot
    Comentar
  3. Samsung Gear VR Lens Replacement, Motherboard: passo 3, imagem 1 %32
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
    Pergunte ao FixBot
    Comentar
  4. Samsung Gear VR Lens Replacement: passo 4, imagem 1 %32
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
    Pergunte ao FixBot
    Comentar
  5. Samsung Gear VR Lens Replacement, Inner Mask: passo 5, imagem 1 %32 Samsung Gear VR Lens Replacement, Inner Mask: passo 5, imagem 2 %32 Samsung Gear VR Lens Replacement, Inner Mask: passo 5, imagem 3 %32
    • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
    • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
    Pergunte ao FixBot
    Comentar
  6. Samsung Gear VR Lens Replacement, Lens: passo 6, imagem 1 %32 Samsung Gear VR Lens Replacement, Lens: passo 6, imagem 2 %32
    • Using the metal spudger, push in the 3 tabs around the lens housing to release the lens. Repeat for both lens for a total of 6 tabs.
    • Do not push in too hard or you might brake the tabs.
    Pergunte ao FixBot
    Comentar
  7. Samsung Gear VR Lens Replacement: passo 7, imagem 1 %32
    • Flip the headgear and use your fingers to gently remove lens from mask. Repeat for both lens.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Membros
Autoria de 7 guias
1Comentário do guia
There are multiple mistakes in this tutorial, which made it hard to follow the steps:
- in step 2.1, you are missing 4 screws below each side of the latching mechanism.
- in step 5, the mask does not come apart after unscrewing the 8 screws. I am currently stuck at this step as I am writing this. Wish me luck.
L.H. - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 46
Ao todo: 6,777
