Introdução
The inner mask lies under the phone mount and requires removal in order to access the lenses and focus wheel assembly. This guide will instruct the user on how to remove the mask from the headset.
The motherboard partially sits on the inner mask piece of the headset and must be removed in order to remove the inner mask piece.
Caution is required while working on the headset as a wire harness connects the USB adapter to the motherboard. Care should be taken not to put any strain on the wire and to open the headset from right to left.
O que você precisa
Remove the front cover to access a plate that holds the phone in place during use.
Remove the four corner screw covers with a metal spudger to reveal four screws.
Remove the sticker located at the top center to reveal two additional screws.
Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
