Ir para o conteúdo principal
Samsung Gear VR Motherboard Replacement
O que você precisa
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: passo 1, imagem 1 %32 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: passo 1, imagem 2 %32 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: passo 1, imagem 3 %32
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: passo 2, imagem 1 %32 Samsung Gear VR  Motherboard Replacement: passo 2, imagem 2 %32
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: passo 4, imagem 1 %32
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
Conclusão
David Forlano
Membro desde: 09/25/17
119 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
Membros da 4
Autoria de 7 guias
Um comentário
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 1,548
