Ir para o conteúdo principal
Samsung Gear S3 Frontier Wristband Replacement
Vídeo de Apresentação
  1. Samsung Gear S3 Frontier Wristband  Replacement, Wristband: passo 1, imagem 1 %32 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: passo 1, imagem 2 %32 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: passo 1, imagem 3 %32
    • Place the watch screen-down so that its back cover is showing.
    • Use your nail to push the small silver ball bearing on the right side downward.
    • If your nails aren't sharp enough, you can use a sharp pointed object such as a toothpick or pen.
    • While the ball is pressed down, pull the wristband outwards until the strap is disconnected from the main frame.
    • For reassembly, hold the ball down and then wedge each pin on the wristband into the pin holes of the main frame.
    • Follow the same steps for the ball on the left side, except this time push the ball upwards and then pull outwards.
Conclusão
Corey Rumbaugh
Membro desde: 10/08/18
1.561 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S15-G2, White Fall 2018 Membro de Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 Membros
Autoria de 34 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 64
Ao todo: 3,017
