Introdução
Is your device completely unresponsive? Did all of the other troubleshooting and replacement guides not fix your problem? If so, there's a good chance your motherboard needs to be replaced. Follow this guide.
O que você precisa
Detach the three connectors on the motherboard using your fingernail.
When reassembling, place the battery into the plastic assembly first. Don’t stick it to the adhesive first. This way, it’s easy to position the battery cable.
When securing the battery cable, make sure the hole that the peg goes through is round. The hole on your replacement battery’s cable could be malformed. You may want to widen the hole before securing the cable.
To widen the hole, use the Pro Tech Toolkit’s SIM tool, a small paperclip or similar fine-tipped tool. The tool can also be used to gently press the battery cable into the correct position. Do this carefully to avoid damage.
Follow steps 8-1 in reverse order to reassmble.
Remove the battery's cable from the chassis using tweezers.
4 outras pessoas executaram este guia.
11 comentários
Try ebay Mel
My button Ribbon on my Mainboard has come detached. It seams like there was some adhesive holding it on so i pressed it together. put it back together but the buttons wont turn the watch on. it is charged. I can’t tell if the Ribbon was soldered on or some adhesive used to make those connections. Any help would be appreciated.
