Ir para o conteúdo principal
Samsung Gear S3 Frontier Front Screen Assembly Replacement
O que você precisa
  1. Samsung Gear S3 Frontier Front Screen Assembly Replacement, Back Cover: passo 1, imagem 1 %32
    • Place the watch screen-down so that its back cover is showing.
  2. Samsung Gear S3 Frontier Front Screen Assembly Replacement: passo 2, imagem 1 %32 Samsung Gear S3 Frontier Front Screen Assembly Replacement: passo 2, imagem 2 %32
    • Remove the four 4.2mm screws with a Y00 screwdriver.
  3. Samsung Gear S3 Frontier Front Screen Assembly Replacement: passo 3, imagem 1 %32 Samsung Gear S3 Frontier Front Screen Assembly Replacement: passo 3, imagem 2 %32 Samsung Gear S3 Frontier Front Screen Assembly Replacement: passo 3, imagem 3 %32
    • This step will ruin the water-proof seal.
    • Wedge the metal spudger in between the back cover and the frame along the seam.
    • Use force to pry the back cover away from the main watch frame.
    • This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
  4. Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: passo 4, imagem 1 %32 Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: passo 4, imagem 2 %32 Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: passo 4, imagem 3 %32
    • Detach the three connectors on the motherboard using your fingernail.
    • The connectors are easy to pop off. Minimal force is necessary.
  5. Samsung Gear S3 Frontier Front Screen Assembly Replacement: passo 5, imagem 1 %32 Samsung Gear S3 Frontier Front Screen Assembly Replacement: passo 5, imagem 2 %32 Samsung Gear S3 Frontier Front Screen Assembly Replacement: passo 5, imagem 3 %32
    • Separate the motherboard and front screen assembly using a spudger.
Conclusão
14 outras pessoas executaram este guia.
Jimmy Algeo
Membro desde: 10/08/18
880 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S15-G2, White Fall 2018 Membro de Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 Membros
Autoria de 34 guias
9Comentários do guia
can you tell me where can i buy the whole front screen  ?
Ahmad Hariki - Responder
Jerzy Jerzyk - Responder
Same question, I am having great difficulty in locating the PARTS to complete these repairs. Can someone please list where we can actually purchase the replacement parts that are shown in these guides??
ArcadeDude44 - Responder
Can anyone please tell, where to get the parts?
Sunny Tate - Responder
Eleazar Lagundino - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 112
Ao todo: 22,136
