Ir para o conteúdo principal
Samsung Gear S2 Watch Strap Replacement
O que você precisa
  1. Samsung Gear S2 Watch Strap Replacement, Watch Strap: passo 1, imagem 1 %32 Samsung Gear S2 Watch Strap Replacement, Watch Strap: passo 1, imagem 2 %32
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Watch Strap Replacement: passo 2, imagem 1 %32 Samsung Gear S2 Watch Strap Replacement: passo 2, imagem 2 %32
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Watch Strap Replacement: passo 3, imagem 1 %32 Samsung Gear S2 Watch Strap Replacement: passo 3, imagem 2 %32
    • Repeat the procedure from step 2 for the other strap.
Conclusão
7 outras pessoas executaram este guia.
Jacob Baldwin
Membro desde: 02/20/17
3.412 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G3, Sullivan Spring 2017 Membro de USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
Membros da 3
Autoria de 23 guias
6 comentários
can you also provide instruction to change home button on Gear S2
thanks
inder kapoor - Responder
you have to buy the continuing transfunctioner to change the home button on the gear s2
i have some for sale if interested
bobby - Responder
Where can you buy new straps?
Olga Andreu - Responder
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
Ryo Kimball - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 68
Duração total: 9,483
