Ir para o conteúdo principal
Samsung Gear S2 Motherboard Replacement
O que você precisa
  1. Samsung Gear S2 Motherboard Replacement, Watch Strap: passo 1, imagem 1 %32 Samsung Gear S2 Motherboard Replacement, Watch Strap: passo 1, imagem 2 %32
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Motherboard Replacement: passo 2, imagem 1 %32 Samsung Gear S2 Motherboard Replacement: passo 2, imagem 2 %32
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Motherboard Replacement: passo 3, imagem 1 %32 Samsung Gear S2 Motherboard Replacement: passo 3, imagem 2 %32
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Motherboard Replacement, Back: passo 4, imagem 1 %32 Samsung Gear S2 Motherboard Replacement, Back: passo 4, imagem 2 %32
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
  5. Samsung Gear S2 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Samsung Gear S2 Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
  6. Samsung Gear S2 Motherboard Replacement: passo 6, imagem 1 %32 Samsung Gear S2 Motherboard Replacement: passo 6, imagem 2 %32 Samsung Gear S2 Motherboard Replacement: passo 6, imagem 3 %32
    • Using a spudger, pry up the three cables.
  7. Samsung Gear S2 Motherboard Replacement: passo 7, imagem 1 %32 Samsung Gear S2 Motherboard Replacement: passo 7, imagem 2 %32
    • Using the flat end of a spudger, pry up the motherboard.
    • Make sure the cable is fed through the hole to avoid damaging it.
    • The motherboard is attached to the battery casing, so place the motherboard in the orientation shown once freed.
Conclusão
7 outras pessoas executaram este guia.
Jacob Baldwin
Membro desde: 02/20/17
3.412 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G3, Sullivan Spring 2017 Membro de USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
Membros da 3
Autoria de 23 guias
6 comentários
Where do you get the mother board.
Walter Meekins - Responder
I'm looking for a new motherboard as well.
Karen -
Where do you buy a motherboard???
kiki3w - Responder
Do you have a good source for motherboards? Hope it helps that I +30’d you!
darkfeather72 - Responder
Ok motherboard replaced but how can I have the watch to work in normal mode and not in factory release.?
Cyan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 29
Duração total: 16,714
