Introdução
Have your applications or watch become unresponsive? Replacing the motherboard may fix these issues.
O que você precisa
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
Using a Philips head #00 screwdriver, remove the two 3.6 millimeter screws.
7 outras pessoas executaram este guia.
6 comentários
Where do you get the mother board.
I'm looking for a new motherboard as well.
Karen -
Do you have a good source for motherboards? Hope it helps that I +30’d you!
