Introdução
This is just a look into the Samsung gear S2.
O que você precisa
Ferramenta utilizada neste passo:Tweezers$4.99
You will need a Y 00 screwdriver, a PH 0 screwdriver, a spudger, and some tweezers.
Pry between the bottom and top portions of the watch with a spudger in the area marked. Be sure not to insert the spudger more than about 3 mm so as not to damage the internals of the watch.
Also, there is a seal inside the watch that goes along the perimeter inside the bottom of the casing. Be sure not to damage this, otherwise you lose water resistance.
26 outras pessoas executaram este guia.
26Comentários do guia
Thank you for a picture of the internals. I'm thinking about "restoring" a Gear S2 classic.
Just updated, sorry about the delay. The guide is now finished.
How do I replace the screen? It seems like it’s glued on.
Hi Austin, tks for making the guide, How to remove the rotating bezel?
This is my own personal watch, so I did not try to remove the bezel. The only way I can think of is by prying up on the bezel from the top. Just be careful as I do not know how or if the bezel is connected to the watch.
