Ir para o conteúdo principal
Samsung Gear 360 Motherboard Replacement
O que você precisa
  1. Samsung Gear 360 Motherboard Replacement, Case: passo 1, imagem 1 %32 Samsung Gear 360 Motherboard Replacement, Case: passo 1, imagem 2 %32 Samsung Gear 360 Motherboard Replacement, Case: passo 1, imagem 3 %32
    • Twist silver ring on the lens counter-clockwise with force to remove it.
  2. Samsung Gear 360 Motherboard Replacement: passo 2, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 2, imagem 2 %32
    • Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
  3. Samsung Gear 360 Motherboard Replacement: passo 3, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 3, imagem 2 %32
    • Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
    • Repeat for the back side of the camera.
  4. Samsung Gear 360 Motherboard Replacement: passo 4, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 4, imagem 2 %32 Samsung Gear 360 Motherboard Replacement: passo 4, imagem 3 %32
    • Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
  5. Samsung Gear 360 Motherboard Replacement: passo 5, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 5, imagem 2 %32
    • Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
  6. Samsung Gear 360 Motherboard Replacement: passo 6, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 6, imagem 2 %32
    • Using a plastic opening tool, pry the tripod mount off the device.
  7. Samsung Gear 360 Motherboard Replacement: passo 7, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 7, imagem 2 %32
    • Using both hands, carefully remove the right cover off the camera body.
  8. Samsung Gear 360 Motherboard Replacement: passo 8, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 8, imagem 2 %32 Samsung Gear 360 Motherboard Replacement: passo 8, imagem 3 %32
    • To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
  9. Samsung Gear 360 Motherboard Replacement: passo 9, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 9, imagem 2 %32
    • Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
    • Repeat for both sides of the camera.
  10. Samsung Gear 360 Motherboard Replacement: passo 10, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 10, imagem 2 %32
    • Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
  11. Samsung Gear 360 Motherboard Replacement: passo 11, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 11, imagem 2 %32 Samsung Gear 360 Motherboard Replacement: passo 11, imagem 3 %32
    • Carefully lift the three sensors off using a plastic opening tool and pull them aside.
  12. Samsung Gear 360 Motherboard Replacement: passo 12, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 12, imagem 2 %32
    • Carefully use a plastic opening tool to separate the gray case from the black case on the device.
  13. Samsung Gear 360 Motherboard Replacement: passo 13, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 13, imagem 2 %32 Samsung Gear 360 Motherboard Replacement: passo 13, imagem 3 %32
    • Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
  14. Samsung Gear 360 Motherboard Replacement, Motherboard: passo 14, imagem 1 %32 Samsung Gear 360 Motherboard Replacement, Motherboard: passo 14, imagem 2 %32
    • Use a plastic opening tool to disconnect the sensors from the motherboard to free it.
  15. Samsung Gear 360 Motherboard Replacement: passo 15, imagem 1 %32
    • Using a PH000 Screwdriver head, unscrew the Phillips #000 0.5 mm screw connected to the motherboard.
  16. Samsung Gear 360 Motherboard Replacement: passo 16, imagem 1 %32 Samsung Gear 360 Motherboard Replacement: passo 16, imagem 2 %32 Samsung Gear 360 Motherboard Replacement: passo 16, imagem 3 %32
    • To remove the motherboard from the device, use a plastic opening tool on the edges and lift up.
Conclusão
Uma outra pessoa concluiu este guia.
Connor
Membro desde: 02/20/17
454 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S3-G5, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Membros
Autoria de 14 guias
1Comentário do guia
What is the part number of the motherboard? Mine is stuck in firmware upgrade state and Samsung won't even look at it.
So maybe a motherboard replacement is the easiest answer.
Thanks
Hane Hormes - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 1,418
