Introdução
Use this guide to replace a broken front camera on your Samsung Gear 360.
Like most other components in the Samsung Gear 360, you can get to the front camera module by completing an almost full tear-down of the device.
O que você precisa
Within gold metal half of the case, unscrew the Phillips #00 0.75 mm screw located on the metal plate using a PH00 screwdriver.
Using a plastic opening tool, remove the metal cover.
Using a PH000 screwdriver head, unscrew both screws on the remaining case.
Use a plastic opening tool to lift the front camera module from the case.
