Ir para o conteúdo principal
Samsung Gear 360 Front Camera Replacement
O que você precisa
  1. Samsung Gear 360 Front Camera Replacement, Case: passo 1, imagem 1 %32 Samsung Gear 360 Front Camera Replacement, Case: passo 1, imagem 2 %32 Samsung Gear 360 Front Camera Replacement, Case: passo 1, imagem 3 %32
    • Twist silver ring on the lens counter-clockwise with force to remove it.
  2. Samsung Gear 360 Front Camera Replacement: passo 2, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 2, imagem 2 %32
    • Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
  3. Samsung Gear 360 Front Camera Replacement: passo 3, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 3, imagem 2 %32
    • Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
    • Repeat for the back side of the camera.
  4. Samsung Gear 360 Front Camera Replacement: passo 4, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 4, imagem 2 %32 Samsung Gear 360 Front Camera Replacement: passo 4, imagem 3 %32
    • Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
  5. Samsung Gear 360 Front Camera Replacement: passo 5, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 5, imagem 2 %32
    • Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
  6. Samsung Gear 360 Front Camera Replacement: passo 6, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 6, imagem 2 %32
    • Using a plastic opening tool, pry the tripod mount off the device.
  7. Samsung Gear 360 Front Camera Replacement: passo 7, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 7, imagem 2 %32
    • Using both hands, carefully remove the right cover off the camera body.
  8. Samsung Gear 360 Front Camera Replacement: passo 8, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 8, imagem 2 %32 Samsung Gear 360 Front Camera Replacement: passo 8, imagem 3 %32
    • To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
  9. Samsung Gear 360 Front Camera Replacement: passo 9, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 9, imagem 2 %32
    • Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
    • Repeat for both sides of the camera.
  10. Samsung Gear 360 Front Camera Replacement: passo 10, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 10, imagem 2 %32
    • Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
  11. Samsung Gear 360 Front Camera Replacement: passo 11, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 11, imagem 2 %32 Samsung Gear 360 Front Camera Replacement: passo 11, imagem 3 %32
    • Carefully lift the three sensors off using a plastic opening tool and pull them aside.
  12. Samsung Gear 360 Front Camera Replacement: passo 12, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 12, imagem 2 %32
    • Carefully use a plastic opening tool to separate the gray case from the black case on the device.
  13. Samsung Gear 360 Front Camera Replacement: passo 13, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 13, imagem 2 %32 Samsung Gear 360 Front Camera Replacement: passo 13, imagem 3 %32
    • Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
  14. Samsung Gear 360 Front Camera Replacement, Speaker: passo 14, imagem 1 %32 Samsung Gear 360 Front Camera Replacement, Speaker: passo 14, imagem 2 %32 Samsung Gear 360 Front Camera Replacement, Speaker: passo 14, imagem 3 %32
    • Within gold metal half of the case, unscrew the Phillips #00 0.75 mm screw located on the metal plate using a PH00 screwdriver.
    • Using a plastic opening tool, remove the metal cover.
  15. Samsung Gear 360 Front Camera Replacement: passo 15, imagem 1 %32 Samsung Gear 360 Front Camera Replacement: passo 15, imagem 2 %32 Samsung Gear 360 Front Camera Replacement: passo 15, imagem 3 %32
    • Using a PH000 screwdriver head, unscrew all Phillips #00 0.75 mm screws.
    • To remove the speaker from the device, use a plastic opening tool on the edge and gently lift it up.
  16. Samsung Gear 360 Front Camera Replacement, Front Camera: passo 16, imagem 1 %32 Samsung Gear 360 Front Camera Replacement, Front Camera: passo 16, imagem 2 %32 Samsung Gear 360 Front Camera Replacement, Front Camera: passo 16, imagem 3 %32
    • Using a PH000 screwdriver head, unscrew both screws on the remaining case.
    • Use a plastic opening tool to lift the front camera module from the case.
Conclusão
Connor
Membro desde: 02/20/17
454 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S3-G5, Sullivan Spring 2017 Membro de USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 854
