Ir para o conteúdo principal
Introdução
This guide will walk you through the process of replacing a broken or defective speaker in a Samsung Gear 2.
Peças
Nenhum componente especificado.
  1. Before disassembling your Gear, be sure it is powered off. To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components. Pry the device open from the other side also if it does not fully disassemble from one side. Pry the device open from the other side also if it does not fully disassemble from one side.
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
  4. Use the pointed side of the spudger to remove the small, orange battery cable. Use the pointed side of the spudger to remove the small, orange battery cable.
    • Use the pointed side of the spudger to remove the small, orange battery cable.
  5. Remove the battery by pulling the white tab on the battery marked "PULL." Make sure the orange battery cable is fully disconnected to avoid ripping it off and tearing it.
    • Remove the battery by pulling the white tab on the battery marked "PULL."
    • Make sure the orange battery cable is fully disconnected to avoid ripping it off and tearing it.
  6. Using tweezers, lift the rectangular speaker from the case. Be careful to not pull too quickly and rip the orange connector cable, which is attached to the case with adhesive.
    • Using tweezers, lift the rectangular speaker from the case.
    • Be careful to not pull too quickly and rip the orange connector cable, which is attached to the case with adhesive.
  7. Use tweezers to carefully grab the connector. Gently pull upwards to detach it from the case and from the adhesive.
    • Use tweezers to carefully grab the connector.
    • Gently pull upwards to detach it from the case and from the adhesive.
Conclusão
3 outras pessoas concluíram este guia.
Devin Mast
Membro desde: 14/04/2014
615 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 13-27, Maness Spring 2014 Membro de Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 Membros
6 Guias de autoria
what happens if I don't put the speakers back?
alejandrayin5 - Responder
If you don't what the gear to make the sound when using camera or video take the speaker out. It works fine its just a speaker. I did that with my gear 2 that I bought march 2015.
Edna - Responder
Where can I buy the speaker?
Bob Wagenvoort - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 3,931
