Introdução
This guide will walk you through the process of replacing a broken or defective speaker in a Samsung Gear 2.
O que você precisa
To remove each strap, locate the metal latches on both sides of the back of the Gear.
Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
Pry the device open from the other side also if it does not fully disassemble from one side.
Use the pointed side of the spudger to remove the small, orange battery cable.
I just broke the Orange battery cable. DAM!!!!! WHAT DO I SUGGEST
How did you do that?
Remove the battery by pulling the white tab on the battery marked "PULL."
Ferramenta utilizada neste passo:Tweezers$4.99
Using tweezers, lift the rectangular speaker from the case.
4 outras pessoas executaram este guia.
3Comentários do guia
what happens if I don't put the speakers back?
Where can I buy the speaker?
