Ir para o conteúdo principal
Samsung Gear 2 Battery Replacement
O que você precisa
  1. Samsung Gear 2 Battery Replacement, Front half and Back half: passo 1, imagem 1 %32 Samsung Gear 2 Battery Replacement, Front half and Back half: passo 1, imagem 2 %32
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Samsung Gear 2 Battery Replacement: passo 2, imagem 1 %32
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Samsung Gear 2 Battery Replacement: passo 3, imagem 1 %32 Samsung Gear 2 Battery Replacement: passo 3, imagem 2 %32 Samsung Gear 2 Battery Replacement: passo 3, imagem 3 %32
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
  4. Samsung Gear 2 Battery Replacement, Battery: passo 4, imagem 1 %32 Samsung Gear 2 Battery Replacement, Battery: passo 4, imagem 2 %32
    • Use the pointed side of the spudger to remove the small, orange battery cable.
    I just broke the Orange battery cable. DAM!!!!! WHAT DO I SUGGEST
    Robert Valdez - Responder
    How did you do that?
    Wes robbins - Responder
  5. Samsung Gear 2 Battery Replacement: passo 5, imagem 1 %32 Samsung Gear 2 Battery Replacement: passo 5, imagem 2 %32
    • Remove the battery by pulling the white tab on the battery marked "PULL."
    • Make sure the orange battery cable is fully disconnected to avoid ripping it off and tearing it.
    I just broke the Orange battery cable what next
Conclusão
26 outras pessoas executaram este guia.
Jonathan Molina
Membro desde: 04/14/14
1.018 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-27, Maness Spring 2014 Membro de Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
Membros da 4
Autoria de 6 guias
15 comentários
Where can one find said replacement battery. I had it on in less than a meter of water for less than 30 minutes and water was able to get in. Even though I did not subject it to its supposed limitations I am fairly certain that best buy or samsung will check the water indicator paper and tell me that it was my fault. I have taken it apart and gotten it all dried out. It will come on and function just fine and then when i unplug it it will turn off after a minute or so. At any rate, I would like to replace my battery but need to find one first.
paul - Responder
Where can I find a battery I have looked everywhere including Ebay and Amazon?
Mike Landriault - Responder
I am looking for a battery also mine is very bad after 1 year. Were you able to find one?
Mimo Caceres -
We're can I find a replacement battery for my gear 2 neo watch looked everywhere
Drock - Responder
www.stellatech.com
berk1 -
Where can i find replacement battery for gear 2 to purchase online ???
abosos86 - Responder
I left my Gear 2 in a drawer for about a year and I couldn't get it to charge. I tried plugging into a usb in a laptop/desktop and a bunch of different cords. Samsung said it would cost $226 to fix, I bought this battery off of ebay and it has been working for the past 3 weeks. I will try and add a comment later after i have had it longer, but so far so good.
http://www.ebay.com/itm/301829821375
mnvikings09 - Responder
I need a battery for my Samsung gear watch but am kisumu n it is not there in samsung branch in kisumu how can i b helped
Elishama Ongonga - Responder
where can I get a replacement battery for a gear 2 neo fd81. Have tried all above links with no joy
James Chigweremba - Responder
I had to hit reset Gear to have reconnect to my phone, it's been stuck in Gear rebooting for a week. Will removing the battery help
anthony stefanese - Responder
The batteries and tools are on eBay. Search for Samsung Gear 2
pbell35 - Responder
My Gear 2 does not light up(or is very dim as if it`s going to fade out). In any case, it does not function. Should the battery be replaced? Or is it something wrong with the display? Please advise.
Mohammad Ali Farhadi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 30
Duração total: 58,058
