Ir para o conteúdo principal
Samsung Galaxy Y s5360 Home Button Replacement
O que você precisa
  1. Samsung Galaxy Y s5360 Home Button Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Galaxy Y s5360 Home Button Replacement, Back Panel: passo 1, imagem 2 %32 Samsung Galaxy Y s5360 Home Button Replacement, Back Panel: passo 1, imagem 3 %32
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Samsung Galaxy Y s5360 Home Button Replacement, Touch Screen/Display: passo 2, imagem 1 %32 Samsung Galaxy Y s5360 Home Button Replacement, Touch Screen/Display: passo 2, imagem 2 %32 Samsung Galaxy Y s5360 Home Button Replacement, Touch Screen/Display: passo 2, imagem 3 %32
    • Use the screwdriver with a Phillips #000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of it's slot.
  3. Samsung Galaxy Y s5360 Home Button Replacement: passo 3, imagem 1 %32 Samsung Galaxy Y s5360 Home Button Replacement: passo 3, imagem 2 %32 Samsung Galaxy Y s5360 Home Button Replacement: passo 3, imagem 3 %32
    • Use the metal pry tool to separate the interior back panel from the interior hardware and screen.
    • Using a metal spudger may cause further damage to your device.
  4. Samsung Galaxy Y s5360 Home Button Replacement: passo 4, imagem 1 %32 Samsung Galaxy Y s5360 Home Button Replacement: passo 4, imagem 2 %32 Samsung Galaxy Y s5360 Home Button Replacement: passo 4, imagem 3 %32
    • Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
  5. Samsung Galaxy Y s5360 Home Button Replacement, Home Button: passo 5, imagem 1 %32 Samsung Galaxy Y s5360 Home Button Replacement, Home Button: passo 5, imagem 2 %32
    • Remove the Home Button from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 959
