Ir para o conteúdo principal
Samsung Galaxy View Kickstand Replacement
O que você precisa
  1. Samsung Galaxy View Kickstand Replacement, Kickstand: passo 1, imagem 1 %32
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Kickstand Replacement: passo 2, imagem 1 %32 Samsung Galaxy View Kickstand Replacement: passo 2, imagem 2 %32 Samsung Galaxy View Kickstand Replacement: passo 2, imagem 3 %32
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
Conclusão
5 outras pessoas executaram este guia.
Jordan Thayer
Membro desde: 10/06/16
535 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-5, Livingston Fall 2016 Membro de Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Membros
Autoria de 12 guias
15Comentários do guia
Where do u buy a replacement kickstand
Bethann Stokes - Responder
The only thing I could find was a broken one on eBay for parts ......
cindylou73 -
I have the same issue! kickstand broke in half (it fell and got broken) and cannot find replacement
Carlos Sierra -
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 44
Ao todo: 9,148
