Ir para o conteúdo principal
Samsung Galaxy Victory 4G Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Place phone face down. Ensure the side with the display screen is not facing you.
    • Locate battery door and slide open.
    • Remove battery.
  2. Samsung Galaxy Victory 4G Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
  3. Samsung Galaxy Victory 4G Motherboard Replacement: passo 3, imagem 1 %32
    • Use the plastic opening tool to pry open the back cover.
    • Insert the tool into the SD card slot and pry around the entire phone.
  4. Samsung Galaxy Victory 4G Motherboard Replacement: passo 4, imagem 1 %32
    • Remove one Phillips 3.93 mm screw from bottom center of the phone.
  5. Samsung Galaxy Victory 4G Motherboard Replacement: passo 5, imagem 1 %32 Samsung Galaxy Victory 4G Motherboard Replacement: passo 5, imagem 2 %32 Samsung Galaxy Victory 4G Motherboard Replacement: passo 5, imagem 3 %32
    • Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing.
  6. Samsung Galaxy Victory 4G Motherboard Replacement: passo 6, imagem 1 %32 Samsung Galaxy Victory 4G Motherboard Replacement: passo 6, imagem 2 %32
    • Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
    • Place your tool under the labeled area and pull gently to detach the ribbon cable from the motherboard.
    • At this point the motherboard should be completely detached from the rest of the phone.
Conclusão
6 outras pessoas executaram este guia.
Zhao
Membro desde: 09/23/14
251 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 15-3, Remmell Fall 2014 Membro de USF Tampa, Team 15-3, Remmell Fall 2014
USFT-REMMELL-F14S15G3
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,582
