Ir para o conteúdo principal
Samsung Galaxy TabPro S Screen Replacement
O que você precisa
  1. Samsung Galaxy TabPro S Screen Replacement, Screen: passo 1, imagem 1 %32
    • Apply heat around the screen to loosen the glue holding in the screen. A heat gun would be preferable as it needs to get relatively warm.
  2. Samsung Galaxy TabPro S Screen Replacement: passo 2, imagem 1 %32
    • Attach the small suction cup near the edge of the screen.
    • Pry in between the screen and the frame with a plastic spudger.
    • Pull up with the suction cup while prying and the screen should begin gently disconnecting.
    • Use the spudger on all edges of the tablet between the screen and the frame.
    • The screen should release.
  3. Samsung Galaxy TabPro S Screen Replacement: passo 3, imagem 1 %32
    • Disconnect the thick cable from the motherboard
    • Disconnect the golden cable from the motherboard
Conclusão
Uma outra pessoa concluiu este guia.
Mitchell Caister
Membro desde: 03/31/22
328 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-4, Harley Spring 2022 Membro de IUPUI, Team 3-4, Harley Spring 2022
IUPUI-HARLEY-S22S3G4
Membros da 3
Autoria de 3 guias
Um comentário
Where to find a replacement screen for a 2017 Samsung tab S pro 12 inch ?!?!?
ori gosi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 769
