Ir para o conteúdo principal
Samsung Galaxy TabPro S Front-Facing Camera Replacement
O que você precisa
  1. Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: passo 1, imagem 1 %32 Samsung Galaxy TabPro S Front-Facing Camera Replacement, Front-Facing Camera: passo 1, imagem 2 %32
    • Remove the back of the tablet by prying the plastic back using a flat tool.
    • When the tool has been inserted under the back, slide it all the way around the tablet to fully unclip it.
  2. Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 2, imagem 1 %32 Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Once the back has been removed, disconnect all cables using a pair of tweezers to avoid damaging any components.
    • Once the cables have been disconnected, remove the battery using a flat plastic tool (not the metal spudger).
  3. Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the screws that secure the motherboard.
    • Remove the metal plate once the screws are gone and the motherboard will be ready to be replaced.
  4. Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 4, imagem 1 %32 Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 4, imagem 2 %32
    • Remove motherboard by prying it up with a flat plastic opening tool (not metal spudger).
    • Be sure that all components have been disconnected beforehand, especially the front-facing camera (located above the motherboard in the top center of the frame).
  5. Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 5, imagem 1 %32 Samsung Galaxy TabPro S Front-Facing Camera Replacement: passo 5, imagem 2 %32
    • Once the camera has been disconnected from the motherboard, it can be removed using a pair of pliers.
Conclusão
Mitchell Caister
Membro desde: 03/31/22
328 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-4, Harley Spring 2022 Membro de IUPUI, Team 3-4, Harley Spring 2022
IUPUI-HARLEY-S22S3G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 269
