Introdução
If you have damaged your Galaxy Tab S3's camera sensor or image stabilization, you will need to replace the camera module. This guide will show you how to properly remove and replace the cameras on the rear of the device.
If you notice that the camera lens is scratched, you will need to replace either the display assembly (front camera) or the rear glass panel (rear camera). A scratch on the camera's outer lens does not constitute damage to the module itself.
  1. To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device.
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device.
    • We used two iOpeners to open up the tablet. The process is doable with a single iOpener, but would take substantially longer. Alternatively, you can use a heat gun to quickly loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Place a suction cup near edge that you heated up with the iOpener.
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. As you continue along the edge using the opening tool, use a plastic card  to keep the glass separate from the midframe.
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display. Pull off the glass panel using the suction cup. Carefully disconnect the ribbon connecting the display assembly to the motherboard.  You can disconnect this ribbon from either end.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Pull off the glass panel using the suction cup.
    • Carefully disconnect the ribbon connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device. Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  7. Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe. Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  8. The midframe should snap off from the device’s logic board.
    • The midframe should snap off from the device’s logic board.
  9. Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger. Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger. Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  10. Use the flat end of the spudger to pop off the connector between the battery and the motherboard. Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  11. Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables. Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  12. The battery should now be removed and detached from the device.
    • The battery should now be removed and detached from the device.
  13. Flip over the device, and carefully push the Rear Camera out of its framing using the spudger. Flip over the device, and carefully push the Rear Camera out of its framing using the spudger. Flip over the device, and carefully push the Rear Camera out of its framing using the spudger.
    • Flip over the device, and carefully push the Rear Camera out of its framing using the spudger.
  14. Flip the motherboard over and locate the ribbon attaching the Rear Camera to the motherboard. Carefully pop off the ribbon from the logic board with the flat end of the spudger. Flip the motherboard over and locate the ribbon attaching the Rear Camera to the motherboard. Carefully pop off the ribbon from the logic board with the flat end of the spudger. Flip the motherboard over and locate the ribbon attaching the Rear Camera to the motherboard. Carefully pop off the ribbon from the logic board with the flat end of the spudger.
    • Flip the motherboard over and locate the ribbon attaching the Rear Camera to the motherboard. Carefully pop off the ribbon from the logic board with the flat end of the spudger.
  15. Remove the Rear Camera from the device.
    • Remove the Rear Camera from the device.
Conclusão
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
2 outras pessoas concluíram este guia.
Zachary Fucini
577 reputação
4 Guides authored
Equipe
Cal Poly, Team S22-G4, Maness Spring 2018 Membro de Cal Poly, Team S22-G4, Maness Spring 2018
CPSU-MANESS-S18S22G4
5 Membros
10 Guides authored
This repair can be done without removing the screen!
hansderaedt - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Todo: 229
