Introdução
If your home button is no longer functioning properly, it may have become worn or gotten stuck over time, this guide can help you replace it.
O que você precisa
Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
Unclip the orange ribbon cable located above the battery using the Blunt ESD Tweezer.
Remove the four black 3mm screws using a PH000 Phillips screwdriver.
Quase terminado!
Conclusão
