Ir para o conteúdo principal
Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement
O que você precisa
  1. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Back Case: passo 1, imagem 1 %32
    • Turn off the tablet before disassembly.
    • Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
  2. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 2, imagem 2 %32
    • The glue is now melted, so using the metal spudger shown, pry open all sides of the tablet.
    • When prying open near the home and touch screen buttons, use a suction cup.
    • Do not stick the metal spudger past these buttons as this may damage your device.
  3. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 3, imagem 2 %32
    • Carefully lift up the screen.
    • There is a ribbon cable attached. Lifting the screen too quickly can damage the cable.
  4. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 4, imagem 2 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 4, imagem 3 %32
    • Remove the ribbon cable using the Metal Spudger.
    • The ribbon may be taped underneath to the grey frame. Gently lift the ribbon to untape it.
  5. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 5, imagem 2 %32
    • Remove all seventeen 3 mm screws using a PH000 Phillips screwdriver.
  6. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 6, imagem 2 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 6, imagem 3 %32
    • Lift the black frame using the two Metal Spudgers shown.
    • On the third picture, there is a Sim Card component that is connected to the frame and back cover. As you lift up the frame, it'll detach. This is normal.
  7. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 7, imagem 1 %32
    • Once lifted, flip the grey frame over.
    • This component connects to the sim card.
    • Remember to click this component back into place when reassembling the tablet.
  8. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Battery: passo 8, imagem 1 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Battery: passo 8, imagem 2 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Battery: passo 8, imagem 3 %32
    • Unclip the orange ribbon cable located above the battery using the Blunt ESD Tweezer.
    • Remove the four black 3mm screws using a PH000 Phillips screwdriver.
  9. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 9, imagem 1 %32
    • Hold the frame and pop the battery off from the other side.
  10. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Home Button: passo 10, imagem 1 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Home Button: passo 10, imagem 2 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement, Home Button: passo 10, imagem 3 %32
    • This is where the ribbon cable for the home button is located.
  11. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 11, imagem 1 %32
    • Unclip the blue ribbon cable using the Blunt ESD Tweezer.
  12. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 12, imagem 1 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 12, imagem 2 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 12, imagem 3 %32
    • Carefully push the cable through the hole to the other side of the frame.
  13. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 13, imagem 1 %32
    • Using the pointed ESD Tweezer, lift up the silver tape.
  14. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 14, imagem 1 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 14, imagem 2 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 14, imagem 3 %32
    • Using your thumb, push the home button to the right and lift up to dislodge it.
  15. Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 15, imagem 1 %32 Samsung Galaxy Tab S2 9.7 Verizon Tablet Home Button Replacement: passo 15, imagem 2 %32
    • Peel the ribbon cable off carefully, it may be glued to the grey frame.
    • Lift the home button.
Conclusão
Divya Prabakaran
Membro desde: 02/20/17
633 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S2-G4, Sullivan Spring 2017 Membro de USF Tampa, Team S2-G4, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 1,353
