Introdução
Is your tablet dying quickly or not charging at all? Your battery may need to be replaced. Follow this guide and you'll know exactly how to do it!
O que você precisa
Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
Unclip the orange ribbon cable located above the battery using the Blunt ESD Tweezer.
Remove the four black 3mm screws using a PH000 Phillips screwdriver.
Quase terminado!
Conclusão
