Introdução
Follow this guide to bring the sound back to your headphones by replacing the auxiliary port.
O que você precisa
Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
This is where the auxiliary port is located.
Remove the black 3mm screw using a PH000 Phillips screwdriver.
Uma outra pessoa concluiu este guia.
