Ir para o conteúdo principal
Samsung Galaxy Tab S2 8.0 Screen Replacement
O que você precisa
Vídeo de Apresentação
  1. Samsung Galaxy Tab S2 8.0 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Working on a device that is turned on may yield an electric shock. Make sure your device is turned off before working on it.
    • Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
  2. Samsung Galaxy Tab S2 8.0 Screen Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab S2 8.0 Screen Replacement: passo 2, imagem 2 %32
    • Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
    • Put an opening pick in the gap created, in between the screen and the panel.
    • Repeat all around device, putting 2 picks on top and bottom, and one on each side.
  3. Samsung Galaxy Tab S2 8.0 Screen Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab S2 8.0 Screen Replacement: passo 3, imagem 2 %32
    • Carefully remove the small suction cup from the corner without moving the screen.
    • Place the small suction cup in the center of the screen and lift to remove screen.
    • Make sure to separate all glue under the middle parts of the screen as well as the edges - use a thin stiff card to slice through it. Avoid the ribbon cable. Do not attempt to lift the screen until all glue is separated.
    • The screen is still connected to the rest of the device by a cable, so don't pull the screen up too quickly.
  4. Samsung Galaxy Tab S2 8.0 Screen Replacement: passo 4, imagem 1 %32
    • Place the plastic opening tool underneath the ribbon cable connecting the screen to the tablet.
    • Carefully lift the plastic opening tool to detach the ribbon from the tablet.
    • Make sure to discharge any static electricity by touching a grounded metal object, like a quarter, before touching the inside of the device.
  5. Samsung Galaxy Tab S2 8.0 Screen Replacement: passo 5, imagem 1 %32
    • The screen is now detached from the rest of the tablet.
Conclusão
8 outras pessoas executaram este guia.
Jonathan Wood
Membro desde: 04/18/17
1.011 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S17-G1, Banghart Spring 2017 Membro de Cal Poly, Team S17-G1, Banghart Spring 2017
CPSU-BANGHART-S17S17G1
Membros da 5
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 63
Duração total: 9,179
