Ir para o conteúdo principal
Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement
O que você precisa
  1. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: passo 1, imagem 2 %32
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: passo 2, imagem 1 %32
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: passo 3, imagem 1 %32
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: passo 4, imagem 1 %32 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: passo 4, imagem 2 %32
    • Gently pry the camera connector away from the motherboard with a plastic opening tool or your fingers.
    • Lift the rear-facing camera module up and away from the device.
Conclusão
Trent Chapman
Membro desde: 10/01/15
1.378 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-15, Maness Fall 2015 Membro de Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 15
Duração total: 1,422
