Ir para o conteúdo principal
Samsung Galaxy Tab S 8.4 Micro USB Port Replacement
O que você precisa
  1. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: passo 1, imagem 2 %32
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: passo 2, imagem 1 %32
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: passo 3, imagem 1 %32
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: passo 4, imagem 1 %32 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: passo 4, imagem 2 %32
    • Remove the two 4 mm Phillips #000 screws securing the micro USB port.
  5. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, disconnect the charge port from the motherboard.
    • Once disconnected, lift to remove the charging port.
Conclusão
32 outras pessoas executaram este guia.
Trent Chapman
Membro desde: 10/01/15
1.378 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-15, Maness Fall 2015 Membro de Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
Membros da 4
Autoria de 12 guias
6 comentários
It is so amazing and it works!
alva chan - Responder
Thanks a lot!
You make me a big economy by doing this myself with YOUR instructions !
Raphael
refelo123 - Responder
What model number is this device specifically? It says WiFi, but I have the same one from a network carrier. Would this charging port work for that? Model sm-707v is the one that I have.
tailoredtoteach - Responder
Thanks for the instructions, it looks simple , so I ordered the docking assembly and I replace it by myself.
You saved me a lot of money, thanks again!
wim-zelf - Responder
With these instructions I ordered part from Amazon and replaced charging port and tablet charges again. Thanks!
Philip Holly - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 52
Duração total: 15,349
