Ir para o conteúdo principal
Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement
O que você precisa
  1. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: passo 1, imagem 2 %32
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: passo 2, imagem 1 %32
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: passo 3, imagem 1 %32
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: passo 4, imagem 1 %32 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: passo 4, imagem 2 %32
    • Remove the two 2 mm Phillips #000 securing the headphone jack.
  5. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: passo 5, imagem 1 %32
    • Disconnect the blue connector by gently popping it off of the motherboard with a plastic opening tool.
  6. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: passo 6, imagem 2 %32
    • Use the metal spudger to pry from the top left corner of the headphone jack/lower speaker assembly.
    • Gently lift the headphone jack/lower speaker assembly free of the device.
  7. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: passo 7, imagem 1 %32
    • Locate the top speaker.
    • Use a plastic opening tool to disconnect the green-gold upper speaker connector from the motherboard.
  8. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: passo 8, imagem 1 %32 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: passo 8, imagem 2 %32
    • Use a spudger to pry the uper speaker up and away from the device.
Conclusão
8 outras pessoas executaram este guia.
Trent Chapman
Membro desde: 10/01/15
1.378 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-15, Maness Fall 2015 Membro de Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 3,336
