Ir para o conteúdo principal
Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement
O que você precisa
  1. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement, Stereo Speakers: passo 1, imagem 1 %32
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
  2. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 2, imagem 2 %32
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 3, imagem 2 %32 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 3, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the 2.5mm Phillips head screw on the top part of the speaker.
  4. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 4, imagem 2 %32
    • Using your fingers, carefully remove the tab that connects the speaker to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 5, imagem 2 %32 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 5, imagem 3 %32
    • Using your fingers, gently remove the speaker from its place.
  6. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 6, imagem 2 %32 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 6, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the 2.5mm Phillips head screw on top of the speaker.
  7. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 7, imagem 2 %32
    • Using your fingers, lift the tab that connects the speaker to the mother board.
  8. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 8, imagem 1 %32
    • Using a nylon spudger, gently lift the round piece that connects to the speaker and remove it from its place.
  9. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 9, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: passo 9, imagem 2 %32
Conclusão
Mario Montoya
Membro desde: 09/12/16
225 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 9-2, Lacy Fall 2016 Membro de USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 621
