Ir para o conteúdo principal
Samsung Galaxy Tab Pro 8.4 Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 2, imagem 2 %32
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 4, imagem 1 %32
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 5, imagem 1 %32
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement, Motherboard: passo 6, imagem 3 %32
    • Remove all the clips that are attached to the motherboard using your fingers or a nylon spudger.
  7. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 7, imagem 2 %32 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 7, imagem 3 %32
    • There are four Phillips head screws (2.5mm) that need to be removed:
    • Two on the charging port, which is the small metallic piece at the bottom of the device.
    • There is one screw that is covered by a small green tape. The tape must be peeled off before the screw under can be removed.
    • The last screw is found on a speaker at the bottom right of the device. Once the screw is removed, the speaker must be removed as well.
  8. Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 8, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 8, imagem 2 %32 Samsung Galaxy Tab Pro 8.4 Motherboard Replacement: passo 8, imagem 3 %32
    • There is a small wire that connects the motherboard to the bottom right corner.
    • Gently pull the end of the wire that attaches the motherboard to the device until the wire is disconnected.
    • After the cord is disconnected, the motherboard can be removed from the tablet by simply lifting it from the device.
Linha de Chegada
5 outras pessoas executaram este guia.
victor johnson
Membro desde: 10/05/16
242 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 9-2, Lacy Fall 2016 Membro de USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 14
Duração total: 2,360
