Ir para o conteúdo principal
Samsung Galaxy Tab Pro 8.4 Charging Port Replacement
O que você precisa
  1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Battery: passo 1, imagem 1 %32
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 2, imagem 2 %32
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 3, imagem 2 %32
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 4, imagem 1 %32
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 5, imagem 1 %32
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: passo 6, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: passo 6, imagem 2 %32
    • Remove the two 2.5mm Phillips #000 screws.
  7. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 7, imagem 2 %32 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: passo 7, imagem 3 %32
    • Gently pull up on tab that connects the charging port to the motherboard
Conclusão
5 outras pessoas executaram este guia.
Jonathan Romine
Membro desde: 09/12/16
1.072 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 9-2, Lacy Fall 2016 Membro de USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
Membros da 4
Autoria de 10 guias
3 comentários
Thank you for your help. You are awesome :-)
Kim Williams - Responder
I did all of this and battery says “not charging” while plugged in. Replaced both battery and port.
Brandon Torzeski - Responder
Hey Thanks guys! I was interested in the data port / charging port flex cable replacement.
It could not be easier. Cheers folks.
Jim Kirkey
Jim Kirkey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 4,023
