Ir para o conteúdo principal
Samsung Galaxy Tab Pro 8.4 Battery Replacement
O que você precisa
  1. Samsung Galaxy Tab Pro 8.4 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 2, imagem 2 %32
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 3, imagem 2 %32
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 4, imagem 1 %32
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Battery Replacement: passo 5, imagem 1 %32
    • The battery should be completely disconnected and the new one can be installed.
Conclusão
21 outras pessoas executaram este guia.
Jonathan Romine
Membro desde: 09/12/16
1.072 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 9-2, Lacy Fall 2016 Membro de USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
Membros da 4
Autoria de 10 guias
Um comentário
Samsung Galaxy tab ki battery 4800 mah
Razwan good ashqui - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 37
Duração total: 12,169
