Ir para o conteúdo principal
Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: passo 1, imagem 2 %32 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: passo 1, imagem 3 %32
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 2, imagem 2 %32
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: passo 3, imagem 2 %32 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: passo 3, imagem 3 %32
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 7, imagem 1 %32
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 8, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 8, imagem 2 %32 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: passo 8, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
Conclusão
3 outras pessoas executaram este guia.
Nicholas Nolan
Membro desde: 02/17/17
805 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S19-G2, Hoffman Spring 2017 Membro de USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 22
Ao todo: 1,083
