Ir para o conteúdo principal
Samsung Galaxy Tab E Lite 7 Kids Battery Replacement
O que você precisa
  1. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: passo 1, imagem 2 %32 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: passo 1, imagem 3 %32
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 2, imagem 2 %32
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: passo 3, imagem 2 %32 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: passo 3, imagem 3 %32
    • Use the plastic opening tool to gently lift the black ZIF (zero insertion force) connector shown within the red circle.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to gently lift black ZIF (zero insertion force) connector shown within the red square.
    • Now gently pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 5, imagem 2 %32 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: passo 5, imagem 3 %32
    • Use the plastic opening tool and gently pry out the battery from the left-hand side.
    • Grab the battery and lift it up.
Conclusão
5 outras pessoas executaram este guia.
Nicholas Nolan
Membro desde: 02/17/17
805 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S19-G2, Hoffman Spring 2017 Membro de USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
Membros da 4
Autoria de 7 guias
Um comentário
Great information.  You need to show how to replace a screen- LCD for a Samsung Galaxy TAB E Lite Kids.
Paul McWilliams - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 3,026
