Ir para o conteúdo principal
Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement
O que você precisa
Vídeo de Apresentação
    1. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement, Digitizer (Screen Replacement): passo 1, imagem 1 %32 Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement, Digitizer (Screen Replacement): passo 1, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Place the Tablet on a flat surface.
      • Gather the required tools : iFixit opening tool, iFixit opening picks, precision tweezers, suction handle, and spudger.
      Pergunte ao FixBot
      Comentar
    2. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 2, imagem 1 %32
      • Place suction handle in the center of the screen. Firmly press it downwards .
      • This is done to help assist lifting the screen once the edges are loose.
      Pergunte ao FixBot
      Comentar
    3. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 3, imagem 1 %32
      • Grab the iFixit pening tool and wedge the sharp end into the corner of the screen. Pry it upwards, lifting up the corner of the screen.
      Pergunte ao FixBot
      Comentar
    4. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 4, imagem 1 %32
      • Place the iFixit opening pick between the lifted corner and the housing to prevent the screen from falling back into the housing.
      Pergunte ao FixBot
      Comentar
    5. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 5, imagem 1 %32
      • Continue around the perimeter of the screen until you have placed the picks in each remaining corner.
      • Be careful removing the double-sided tape while lifting the screen so that the screen does not break.
      Pergunte ao FixBot
      Comentar
    6. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 6, imagem 1 %32
      • Grab the suction handle and gently lift the screen towards the top of the tablet.
      • Take care while lifting the screen to avoid damaging the ribbon cable at the top of the tablet.
      Pergunte ao FixBot
      Comentar
    7. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 7, imagem 1 %32
      • Place the removed screen that is still attached to the ribbon cable flat on the table.
      Pergunte ao FixBot
      Comentar
    8. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 8, imagem 1 %32
      • Grab the iFixit opening tool and wedge the sharp end into the corner of the housing and pry upwards.
      • Place an iFixit opening pick between the housing and the LCD assembly.
      Pergunte ao FixBot
      Comentar
    9. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 9, imagem 1 %32
      • Continue along the outer edge of the housing until you have placed an iFixit opening pick in each corner.
      Pergunte ao FixBot
      Comentar
    10. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 10, imagem 1 %32
      • Remove the LCD assembly from the housing and place it face down on the table.
      Pergunte ao FixBot
      Comentar
    11. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 11, imagem 1 %32
      • Locate the ribbon cable connector on the back of the LCD assembly.
      • Use the spudger to pry the connector tab upwards.
      • Pull the the ribbon cable to remove it from the connector
      Pergunte ao FixBot
      Comentar
    12. Samsung Galaxy Tab E 9.6 Wi-Fi Digitizer (Screen Replacement) Replacement: passo 12, imagem 1 %32
      • Once the ribbon cable is removed, pull the screen off of the motherboard and place it to the side.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
Juelma
Membro desde: 05/22/19
253 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S4-G4, Wilson Summer 2019 Membro de IUPUI, Team S4-G4, Wilson Summer 2019
IUPUI-WILSON-SU19S4G4
4 Membros
Autoria de 44 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 44
Ao todo: 6,426
