Introdução
To replace a broken screen for this tablet, the user has to ensure that they have all the tools needed. For this project the costumer would need the iFixit opening tool and the picks. After gathering all the needed tools, begin by placing the tools and the tablet on a hard surface like a table. After that, use the opening tool to get in one of the sides of the tablet and slide that to go around the entire tablet. Place the picks in each corner as you go around. Now the screen is ready to be removed. Grab the new screen and pull the plastic cover. Clean the tablet screen using a cleaning wipe and place the new screen. After closing everything you press the new screen down to ensure proper placement. You should be able to use the tablet at this point.
O que você precisa
Vídeo de Apresentação
Place the Tablet on a flat surface.
Gather the required tools : iFixit opening tool, iFixit opening picks, precision tweezers, suction handle, and spudger.
6 outras pessoas executaram este guia.
