Ir para o conteúdo principal
Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement
O que você precisa
  1. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement, Camera Replacement: passo 1, imagem 1 %32 Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement, Camera Replacement: passo 1, imagem 2 %32
    • Place the Tablet on a flat surface
    • Gather the required tools: iFixit opening tool, iFixit opening picks, precision tweezers, suction handle, and spudger.
  2. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 2, imagem 1 %32
    • Place suction handle in the center of the screen. Firmly press it downwards.
    • This is done to help assist lifting the screen once the edges are loose.
  3. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 3, imagem 1 %32
    • Grab the iFixit opening tool and wedge the sharp end into the corner of the screen. Pry it upwards, lifting up the corner of the screen.
  4. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 4, imagem 1 %32
    • Place the iFixit opening pick between the lifted corner and the housing to prevent the screen from falling back into the housing.
  5. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 5, imagem 1 %32
    • Continue around the perimeter of the screen until you have placed the picks in each remaining corner.
    • Be careful removing the double-sided tape while lifting the screen so that the screen does not break.
  6. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 6, imagem 1 %32
    • Grab the suction handle and gently lift the screen towards the top of the tablet.
    • Take care while lifting the screen to avoid damaging the ribbon cable at the top of the tablet.
  7. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 7, imagem 1 %32
    • Place the removed screen that is still attached to the ribbon cable flat on the table.
  8. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 8, imagem 1 %32
    • Grab the iFixit opening tool and wedge the sharp end into the corner of the housing and pry upwards.
    • Place an iFixit opening pick between the housing and the LCD assembly.
  9. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 9, imagem 1 %32
    • Continue along the outer edge of the housing until you have placed an iFixit opening pick in each corner.
  10. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 10, imagem 1 %32
    • Remove the LCD assembly from the housing and place it face down on the table.
  11. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 11, imagem 1 %32
    • Locate the ribbon cable connector on the back of the LCD assembly.
    • Use the spudger to pry the ZIF connector lock tab upwards.
    • Pull the the ribbon cable to remove it from the connector.
  12. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 12, imagem 1 %32
    • Use the curved precision tweezers and carefully peel off the protective green film on top of the camera connector.
  13. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 13, imagem 1 %32
    • Use the spudger and gently pry the ZIF connector lock tab upwards, releasing the ribbon cable.
  14. Samsung Galaxy Tab E 9.6 Wi-Fi Camera Replacement Replacement: passo 14, imagem 1 %32
    • Grab the camera and pull up and away from the connector.
Conclusão
Matthew Skoog
Membro desde: 05/22/19
247 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S4-G4, Wilson Summer 2019 Membro de IUPUI, Team S4-G4, Wilson Summer 2019
IUPUI-WILSON-SU19S4G4
4 Membros
4 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 421
