Ir para o conteúdo principal
Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement
O que você precisa
  1. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Back Casing: passo 1, imagem 1 %32
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: passo 2, imagem 2 %32 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: passo 3, imagem 2 %32 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: passo 3, imagem 3 %32
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Speaker: passo 4, imagem 1 %32 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Speaker: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Locate the speaker in the top right corner of the back casing. Use a pair of tweezers to pull peel up the film connecting the speaker to the case.
  5. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: passo 5, imagem 2 %32
    • Once you've detached the film connecting the speaker to the case, use the tweezers to remove the speaker completely.
Conclusão
Dave Dorzback
Membro desde: 09/28/16
626 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-4, Cagle Fall 2016 Membro de USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
Membros da 3
Autoria de 14 guias
2 comentários
Then what? How does this fix the problem? Can I tweek the speaker? Do I buy a new, more powerful speaker? What is your point in this post?
Janet - Responder
@Janet Sorry I know you probably wont even see this, but its to help those who wish to replace a broken speaker, its not about implanting a 9” subwoofer. Sorry but sometimes the simplest of explanations will often answer your questions.
sannas30 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 1,363
