Ir para o conteúdo principal
Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement
O que você precisa
  1. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement, Back Casing: passo 1, imagem 1 %32
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: passo 2, imagem 2 %32 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: passo 3, imagem 2 %32 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: passo 3, imagem 3 %32
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
Conclusão
Dave Dorzback
Membro desde: 09/28/16
626 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-4, Cagle Fall 2016 Membro de USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 2,665
