Ir para o conteúdo principal
Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement
O que você precisa
  1. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement, Back Camera: passo 1, imagem 1 %32
    • Make sure the device is turned off.
    • Using the plastic opening tool, start in the center and wedge the angled tip between the plastic back and the scree.
    • Try to pressure it, wedge it back and forth.
    • Do not wedge the plastic opening tool directly on top of the power buttons and headphone buttons.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 2, imagem 2 %32
    • Once the bottom edge has been loosened, use the suction tool to pull it.
    • The second picture shows the internal portion of the tablet once the back cover is removed.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 3, imagem 2 %32
    • The first picture shows the location of back camera.
    • Disconnect the rectangular connection from the back camera to the motherboard.
  4. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: passo 4, imagem 2 %32
    • The picture illustrates what the device should look like once the back camera is removed.
Conclusão
Tingting Liu
Membro desde: 09/28/16
25 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-4, Cagle Fall 2016 Membro de USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 1,259
