Ir para o conteúdo principal
Samsung Galaxy Tab E 8.0 Screen Replacement
O que você precisa
  1. Samsung Galaxy Tab E 8.0 Screen Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement, Back Panel: passo 1, imagem 2 %32
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. Samsung Galaxy Tab E 8.0 Screen Replacement, Back Camera: passo 2, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement, Back Camera: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to lift the switch connecting the back camera to the motherboard.
    • Use your hand to remove the back camera from the motherboard.
  3. Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: passo 3, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: passo 3, imagem 2 %32 Samsung Galaxy Tab E 8.0 Screen Replacement, Front Camera: passo 3, imagem 3 %32
    Comprar
    • Use the tweezers to lift the switch connecting the front camera to the motherboard.
    • Remove the front camera from the motherboard by lifting with the tweezers.
  4. Samsung Galaxy Tab E 8.0 Screen Replacement, Motherboard: passo 4, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement, Motherboard: passo 4, imagem 2 %32
    Comprar
    • Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
    • Release the strap from the switch by lifting the strap with your hand.
  5. Samsung Galaxy Tab E 8.0 Screen Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement: passo 5, imagem 2 %32
    • Use the tweezers to flip the switch that connects the top of the strap to the motherboard.
    • Lift the top end of the strap with your hand and remove the strap completely from the device.
  6. Samsung Galaxy Tab E 8.0 Screen Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement: passo 6, imagem 2 %32
    • Use the tweezers to flip the switch of the connector.
    • Lift the connector from the motherboard.
    • This connector does not come completely off, but disconnects from the motherboard.
  7. Samsung Galaxy Tab E 8.0 Screen Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement: passo 7, imagem 2 %32
    • Use the tweezers to flip the switch of the blue connector on the motherboard.
    • This switch can detach from the device, but just needs to disconnect from the motherboard.
    • Ensure the blue ribbon cable is not under the motherboard upon reassembly.
  8. Samsung Galaxy Tab E 8.0 Screen Replacement: passo 8, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement: passo 8, imagem 2 %32
    • Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
  9. Samsung Galaxy Tab E 8.0 Screen Replacement: passo 9, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement: passo 9, imagem 2 %32
    • Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard.
    • Lift the motherboard with your hand to detach the motherboard from the device.
  10. Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: passo 10, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: passo 10, imagem 2 %32 Samsung Galaxy Tab E 8.0 Screen Replacement, Battery: passo 10, imagem 3 %32
    Comprar
    • Use the tweezers to lift the flap on the left end of the battery and pull up with your hand to remove the battery.
    • The battery is held by an adhesive on the back, so it will take some force to remove.
  11. Samsung Galaxy Tab E 8.0 Screen Replacement, Screen: passo 11, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement, Screen: passo 11, imagem 2 %32
    • Use an iOpener or a heat gun/hair dryer to warm the outer 1/2 inch of the screen. It should be very warm but not too hot to touch or you may cause heat damage to components inside the device.
    • Use the iFixit Opening Tool to get between the plastic screen and the device to pry off the screen.
    • The metal spudger may be needed to get between the screen.
    • The metal spudger may cause more damage to the screen if used with force.
  12. Samsung Galaxy Tab E 8.0 Screen Replacement: passo 12, imagem 1 %32 Samsung Galaxy Tab E 8.0 Screen Replacement: passo 12, imagem 2 %32
    • Use the metal spudger to get between the device and the internal screen.
    • Pry out the screen from the device.
Conclusão
6 outras pessoas executaram este guia.
Christian Bloemhof
Membro desde: 10/08/18
1.102 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S13-G4, White Fall 2018 Membro de Cal Poly, Team S13-G4, White Fall 2018
CPSU-WHITE-F18S13G4
Membros da 4
Autoria de 8 guias
Um comentário
I am working on a 7” lite E. Is the procedure about the same?
George Tedrick - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 58
Duração total: 9,079
