Ir para o conteúdo principal
Samsung Galaxy Tab A 9.7 Speakers Replacement
O que você precisa
  1. Samsung Galaxy Tab A 9.7 Speakers Replacement, Back Cover: passo 1, imagem 1 %32
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: passo 2, imagem 1 %32 Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: passo 2, imagem 2 %32
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Samsung Galaxy Tab A 9.7 Speakers Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Heavy-Duty Spudger
    Comprar
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
Conclusão
Paulina Nguyen
Membro desde: 04/26/17
982 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S1-G3, Livingston Spring 2017 Membro de Cal Poly, Team S1-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S1G3
1 Membro
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 26
Duração total: 1,518
